Here is a set of two accessory 9 volt battery powered LED sidelights or tail light adapters. They have spring clamps that slip over the lamp burners in the sidelights or tail lights. They turn on with simple switch on face and use a 9 volt battery. They are bright and take a minute to install. No modifications to original lamps, snap in and away you go. Bought years ago and rarely used. Not made anymore. Perfect safety item or for that dusk cruise you like to take in your T on hot summer nights. 80.00 shipped lower 48
Accessory Battery Powered Sidelight LED Lights
Topic author - Posts: 1443
- First Name: Ed
- Last Name: Martin
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
Re: Accessory Battery Powered Sidelight LED Lights
ED. Ill buy them. PM sent.
