Atwater Kent Front Plate K2 Distributor SOLD
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Aug 06, 2022 2:58 pm
Here is a non generator early Atwater Kent K2 cast iron, automatic advance, front plate distributor for the Model T Ford. It is complete except for the cam drive gear, which is still being sold by the vendors. Includes the correct Atwater Kent coil. The coil is neat because it has a “kick switch” starter button on it for “free starting” on battery. This distributor is considered a project because it needs the points mechanism gone through and adjusted, and a crack that needs to be brazed on neck due to clamp over tightening. (The distributor is still held in the front plate solidly and has a brass set screw on neck that keeps distributor in time and appears to have been running that way fine in the past) includes a copy of original instructions and a set of new distributor cloth wires. 300.00 includes shipping to lower 48.
Last edited by ThreePedalTapDancer on Sat Aug 13, 2022 5:52 am, edited 6 times in total.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Atwater Kent K2 Distributor
Post by ThreePedalTapDancer » Sat Aug 06, 2022 2:59 pm
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Aug 06, 2022 3:00 pm
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Aug 06, 2022 3:02 pm
Points description from internet
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Aug 06, 2022 3:04 pm
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Atwater Kent Front Plate K2 Distributor
Post by ThreePedalTapDancer » Sun Aug 07, 2022 8:41 am
Price change 275 includes shipping lower 48
