WTB - Commutator control rod swivels
Topic author - Posts: 56
- First Name: Jerry M
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring1927
- MTFCA Number: 31760
- MTFCI Number: 24585
I need a couple of commutator control rod swivels - P/N 3534S. Chaffins doesn't make them anymore so none of the vendors (that I contacted) are oit of them as well. If no one has some new units, I would take good used ones, just advise what you have, how much and how you want to get paid.
Jerry Young
Jerry Young
- Last Name: Young
Re: WTB - Commutator control rod swivels
Meant to say, "so the vendors"
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
I’ve got a bunch. I can spare a few
- Last Name: Young
how much, how do you want to get paid and can I get four?
- First Name: GG
Let me dig them out. Shoot me a email so I can send you a few photos
Jerry, be aware that original swivel joints are going to be threaded 12-32...not a common thread (actually, 7/32 - 32, but you're not going to find that easily unless you go online...however, with some effort, you may find 12-32).
An excellent source for obsolete taps/dies is: Drillsandcutters.com
NH Full Flow Float Valves
- Last Name: Young
Scott, thanks for the information, I had discovered that trying to find a replacement - GG will sent email via PM, Thanks to all
Jerry
Jerry
- Last Name: Young
By the way, 12-32 taps and dies are available on Amazon, not sure of the quality, FWIW
Hi Jerry
if the supplier listed is "Drills and Cutters" in the Amazon ad, I can recommend their High Speed Steel products as I have been a customer for oddball things over the years. Sometimes they are USA, sometimes Japan, but usually CHINA. In a REALLY tough bind, the carbon steel tools are useful for about 2 uses in brass and that's about it, but they are really intended to chase and clean up existing threads and then be lost into the bottom of a tool box never to be seen or used again.
- Last Name: Young
Scott, thanks for the update, I don't recall the country of origin for the Amazon parts, however, I did find the taps and dies on the website you mentioned, price not bad either.
Jerry
Jerry
- First Name: Layden
- Last Name: Butler
I can supply a very limited number of the proper timer control rod swivels with nut. They are NOS New Old Stock and there will be no more when these are gone. If you do not have a threaded rod, I will throw in ( until they run out) a later control rod that you could cut off the end and thread for the swivel. Priced at $45 each, domestic postage $10. Let me know if you prefer bare iron or bright.
- Last Name: Young
Layden, I found some (Used) that are on the way to me, thanks for your response, I will keep your information for future reference.
Jerry
Jerry
