WTB American Bosch Distributor Parts
Topic author - Posts: 1039
- First Name: bryant
- Last Name: shafer
- * REQUIRED* Type and Year of Model Ts owned: 1926 tudor
- MTFCA Number: 51736
I know it’s not easy but Iam looking for parts for the American Bosch distributor. Type T-448. Manly the distributor cap. Part#65942. Also any surviving information books on the distributor. Thanks
- First Name: Tom
- Last Name: VanMeeteren
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
Re: WTB American Bosch Distributor Parts
Bryant, see my post in the General discussion regarding these dist caps.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Hi Bryant,
I have a cap in a little better shape than the one pictured. In the past I have used the drive & adapted to a 009 Bosch distributer Then if wanted can go to Pertronics electronic ignition.
- MTFCA Number: 52564
A point you might want to think about. Most of these old units, the shaft and bushings/body are worn. With wear, you change your cylinder firing as the shaft wobbles and the air gap between the cap and rotor changes. A car putting around at 35 or less, might not be much of an issue, but ideally you want that gap to stay pretty close to the same all the time.
1920 Dodge touring
1920 Dodge touring
- First Name: TIMOTHY
- Last Name: ELDER
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout
- MTFCA Number: 24868
Be careful. Caps for Bosch front plate distributors are not the same as caps for clip-on style distributors.
- Last Name: shafer
thanks for the heads up! I’ve been doing research till Iam blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.Jerry VanOoteghem wrote: ↑Tue Aug 16, 2022 2:08 pmBe careful. Caps for Bosch front plate distributors are not the same as caps for clip-on style distributors.
Bryant
I believe the one shown by Sir Tim is for a clip-on. Notice how yours has a "male" locating lug, versus Tim's which has a groove for location.Bryant wrote: ↑Tue Aug 16, 2022 3:04 pmthanks for the heads up! I’ve been doing research till I am blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.Jerry VanOoteghem wrote: ↑Tue Aug 16, 2022 2:08 pmBe careful. Caps for Bosch front plate distributors are not the same as caps for clip-on style distributors.
Bryant
- Last Name: shafer
Rolling The Dice
Looking for the oil cup for the distributor shaft. Attached to the outside of distributor housing.
Bryant
Bryant
It is not an "oil cup" but a "grease cup". Grease cups are designed to push grease into whatever
- Attachments
- ab cup.png (233.79 KiB) Viewed 2552 times
- Last Name: shafer
Here’s an example
I did see the clip on Bosch had the grease version. This distributor has to travel through an empty space about an inch. I think it may have had a wick. Thanks jerry for the pictures
Here's another part to look for. It's a rare find though. Hard to make it out in the photo, but the thumbnut has the "AB" American Bosch logo cast into it. Obviously not a necessity, but kinda cool if you can find one.
- Last Name: shafer
Rolling the dice
Can I get a condenser? Anyone? Don’t be shy
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
The condenser does not have to be inside the distributor.
Follow that distributor wire to the coil and place the condenser there.
All those little round condensers with the pig tail wire are the same size as an early Ford coil condenser.
Some of the coil bands have a small area about 3/8th inch square with a tapped hole in it for a screw to hold the condenser band.
Look for one of those.
- First Name: Tom
Bryant, I have them NOS contact me again Tom
- Last Name: shafer
sounds good email sent
- First Name: Tom
I have NOS point sets, rotors, resistance units and condensers available for the Bosch units. As mentioned before, no caps available at this time. Thinking about reproducing them, but still not enough interest. Included is pictures of the resistance unit and the condenser (if I finally got them loaded
- First Name: Tom
picture of the condenser
- First Name: Tom
darn condenser won't load
- First Name: Tom
[image][/image]3rd try on the condenser
- First Name: Tom
Condenser - try again
- Last Name: shafer
Hey Tom
What’s your price on the condenser?
Bryant
- Last Name: shafer
Trying to find the cam and distributor shaft gears for this unit..
Still looking for the oil cup
Bryant
Bryant
Chaffin's Garage, page 47.
A little cheaper at Lang's...
https://www.modeltford.com/item/BO2.aspx
You might need this too?
https://www.modeltford.com/item/BO-LN.aspx
Hope this helps Not sure what the difference is in Models "Type FI-513" and "Type T-448"
Whats the issue with the cam?
The conversion PDF discusses some measurements and options.
Instructions & parts list FI-513. --
from the above --
from your earlier post T-448 --
Points & your missing parts look the same as a Model 600 --
Conversion to electronic ignition
from the above --
- First Name: Paul
- Last Name: Geil
- * REQUIRED* Type and Year of Model Ts owned: 24 Tudor, 27 Touring, 27 RPU, 27 TT, 14 Touring, 16 touring, 11 Touring, 29 Model A 4-door town sedan, 31 Tudor sedan,
Bryant, I have this Bosch distributor that I removed from a running T. If you’re interested, let me know.
- Last Name: shafer
Thanks Jerry! I think I’ve seen those before but wasn’t clear if they where for my distributor.
Thanks Frank for all the good info! The gears I have look to be repaired and I don’t think I will trust them.
Paul I sent you a email
Bryant
Bryant
