I have one of the exhaust pipes that Original Smith made a couple of years ago.
I remember reading that it used a somewhat different exhaust manifold than the traditional one the vendors carry.
Does anyone have an exhaust manifold that this exhaust pipe will work with?
WTB Exhaust Manifold
Topic author - Posts: 244
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- MTFCA Number: 93
- Board Member Since: 2011
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: WTB Exhaust Manifold
It uses the same exhaust manifold as stock if it has the flared end. The pipe itself that Mr Smith made, just has the correct bends like the original.
1920 Dodge touring
1920 Dodge touring
- First Name: Bill
- MTFCA Number: 93
Mark;
Would you have a picture of the flared end? I'm afraid I don't know what the flared end looks like.
A picture would be helpful, big time.
Thank you, Mark.
Bill Everett
Thank you, Mark.
Bill Everett
Are you taking about the pipes with the straight ends that were held in the exhaust manifold with a pack nut? or the type shown above. If the straight ended pipe, then yes, it is a different manifold. The last ones I recall Mr Smith making were the flare style. Please edit your ad with the year and better description of what you need. (For your 1911 maybe?) Click on the pencil, you can then edit your title too.
1920 Dodge touring
1920 Dodge touring
