WTB Speedometer gear - Found One!
Topic author - Posts: 100
- First Name: Bryce
- Last Name: S
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster
- MTFCA Number: 52112
Today I was driving and happened to look down and noticed my speedometer was dead in the water.... I got out and immediately went to the right front wheel and saw the smaller gear nut had backed off and chucked the gear. I walked the road for 2 hours looking for it. I have no idea if it was fiber or metal. It's a Johns-Manville Speedometer. I would greatly appreciate any information. I am attaching pictures of everything.
- First Name: Ed
- Last Name: Martin
Re: WTB Speedometer gear
I think they look like this and are made of fiber. Check with Russ Furstnow the speedometer rebuilder, he would know. If not, This place may have them.
http://antiquespeedometer.com/index.htm
- First Name: Bryce
- Last Name: S
I am not really sure if it was fiber but as long as it fits I'm sure it will be fine. I will give it a shot tomorrow and call. I feel like it might have been metal especially due to the wear on the wheel gear itself. Thank you very much for the information.
- MTFCA Number: 14972
- MTFCI Number: 15411
The majority of drive pinions were fiber - seen a couple metal ones, though.
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
- MTFCA Number: 17802
I don't know if this is the one you are looking for, but I have this one I would sell.
I'd be more concerned with the road wheel. It certainly looks experienced. There appear to be register marks on the outside circle of the wheel bolts, perhaps indicating that something might well have been in play to cause the departure of the speedo gear. Also, those nuts are on wheel bots which have not been staked to keep them from becoming loose.
- First Name: Ed
- Last Name: Martin
The wheel gear needs to be removed and the teeth filed and cleaned up. The swivel or something has made obvious contact with the teeth, and that gear will quickly chew up a new fibre gear in its present state.
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet
- MTFCA Number: 28
- MTFCI Number: 10546
The fiber pinion gear you need is a 12T8P gear. I have them in stock. 1stnow@msn.com I hope this helps, Russ Furstnow
- First Name: Russ
- MTFCA Number: 28
Bryce, After looking at your photos, I noted that you are missing the collar and thin nut that holds the fiber pinion in place. Check out the photos of the parts of the drive and you can see the collar and nut. I hope this helps, Russ Furstnow
- First Name: Bryce
- Last Name: S
Thank you John, I appreciate it but the one that came off of it was a 12 tooth.John iaccino wrote: ↑Mon Sep 19, 2022 7:22 amI don't know if this is the one you are looking for, but I have this one I would sell.
- First Name: Bryce
- Last Name: S
Well after a total walking time of the near 3 block stretch of road I have yet to find the gear that has the collar which mates to that gear which Russ informed me I would need as well. Pretty unfortunate but those are the cards that were dealt.
- First Name: Bryce
- Last Name: S
All, I just wanted to give a shout out to Russ. He got me all squared away and Dad's "T" will be in working order soon enough. Very grateful for this forum.
