SR FRONTY CYLINDER HEAD +++
Posted: Sun Oct 09, 2022 10:23 pm
Reconditioned SR Fronty cylinder head, dual port 8 sparkplugs, new valves, springs, pressure tested and surfaced. Complete with all rockers, stanchions and push rods all new grade 8 head bolts and head gasket and valve cover.
Polished finned aluminum side covers, polished Fronty sump and spacer. Gear drive water pump and mag drive(possible Fronty? goes in place of generator
, Oil pump, 26/27 pan modified for oil drain transmission to pan, included is a distributor front cover and a 8 cylinder distributor to fire all 8 spark plugs, also included is a new Nissan 8 cylinder distributor cap and rotor for dual plugs. A header exhaust is included. There is an aluminum intake with 2 SU carbs(manifold will have to be modified. A new aftermarket fan and crank pully V-belt also plus a waterpump with v belt pully
$5500.00 plus shipping and crating
I will provide detailed photos as you require. I'm an old guy and putting photos here is too damn difficult. Either text me or email for clear detailed photos. I'm 79 better buy it before I croak, and my heirs give it to the junk man.
frontyboy 2h06919-1949(Seattle)
