FS Stromberg OF carburetor.
Posted: Thu Nov 03, 2022 7:44 am
As shown in photos. Excellent original condition. Even the needle rod still has its two ears for the float level adjustment. All complete, with economiser lever roller free to work.
Two minor departures from standard. The threaded holes for the manifold mounting bolts have been reamed it to take standard 3/8" nuts and bolts, and the holes elongated a little to fit a wider intake. The fixed throttle arm has been removed for RHD use. In its place is a cast brass arm, which can positioned for LHD just as well.
$380 posted to your door.
