As the title says, I'm looking for a nice 7-leaf taper leaf rear spring, the closer to Western Pennsylvania the better. Would consider an 8 leaf also.
Thanks,
Dave Carter
Wanted 7-leaf Taper Leaf Rear Spring
- Last Name: Nunn
- MTFCA Number: 50321
Re: Wanted 7-leaf Taper Leaf Rear Spring
Omaha craigslist has a frame with tapered rear spring listed. It has the riveted spring clip. Not my ad but maybe this helps.
https://omaha.craigslist.org/pts/d/omah ... 00546.html
- First Name: dino
- Last Name: marinelli
- MTFCA Number: 35645
I have a partial set, the bottom four, you can have for free if your interested, just pay shipping, you can probably pick up the last three easy or make them since they do not show to much
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Did you ever find the spring set ?
