WANTED L&R T-28 Ultrasonic Cleaner Manual or Schematic
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Mon Dec 05, 2022 8:39 am
My L&R Ultrasonic Cleaner looks like new and is low useage, but has three resistors that are rather burnt.
With a schematic or manual to determine why they may have toasted, I can repair this unit.
The company in New Jersey is no help!
Re: WANTED L&R T-28 Ultrasonic Cleaner Manual or Schematic
Post by Scott_Conger » Mon Dec 05, 2022 9:44 am
Jim I do wish you luck!
I had a gorgeous 3 gallon unit which I unwittingly allowed to run low on liquid in a 110F shop two summers ago and zorched the electronics. They do not like to run with more than around 1" of the inner wall being dry.
That said, after finding an outfit that would look at my unit (Denver, I think), IF they could repair it, it would be $750+
I held my nose and bought a big VEVOR unit and am almost unhappy to say that it is great. My L&R was 10 years old with probably 3 hours total on it and cost $1250. The VEVOR cost about $125 and after 120 hours is still going strong.
On the positive side, it is powerful and will blast holes in aluminum foil coupons anywhere in the tank. The downside is that the entire unit is made from very flimsy stock and with no sound absorption material in the housing it is almost ear-splitting...hearing protection recommended. Two summers and maybe 120 hours of use and it is just fine.
I wish you luck on the schematic. I came up with bupkis
NH Full Flow Float Valves
Post by TRDxB2 » Mon Dec 05, 2022 12:55 pm
I found this use manual online. Its a link to a PDF file that you can down load https://www.lrultrasonics.com/_media/re ... manual.pdf
Lists 4 service centers in the USA
Post by Scott_Conger » Mon Dec 05, 2022 1:37 pm
Nice of you to locate and publish this Frank
I hope Jim can get some help but I found that the service centers will only work on Warrantee units. Mine was unfortunately out of Warrantee due to age. Maybe Jim will be luckier than I.
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Wed Dec 07, 2022 7:28 pm
What solution to you guys use in these tanks? I have one but have never used one before. Does it make a difference what material your cleaning? Thanks
1912 Torpedo Roadster
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Thu Dec 08, 2022 5:27 pm
A small part can be put in a glass jar with any solution you wish to use and the jar just put in the tank solution.
I have not been able to find a schematic to determine what size the three burned resistors are.
There are several possibilities on why they burned.
Most likely the unit was left running way too long or there was a lightning bolt that came down the power line.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Mon Dec 11, 2023 10:14 am
I still need the L&R Ultrasonic Cleaner with or the manual!
