Looking for the flat trim piece for the floor board that goes around the parking / high gear lever 1911-1919 style. Steel is preferred original or reproduction.
Thanks in advance. 423-2eight4-97fifty. Text pictures of what you’ve got and price.
WTB—> Emergency Brake lever floor trim.
Topic author - Posts: 240
- Last Name: McClelland
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
Re: WTB—> Emergency Brake lever floor trim.
Got one for you. Sent you a text. ctleonard64@gmail.com
The trim piece Mike has isn’t the right one it is a stamped with a small flange.
I need the flat one without a inner flange around the inner hole, it’s about thick as a dime not thin stamped metal.
So I’m still looking for a (flat) trim piece for parking brake lever… This is the one for 1911-1919
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
sent you an email
Melba I got the email, no pictures though. Thanks
I have one in steel - no idea if new or repro but its thick as 2 dimes and no inner flange/ Will text a picture to youRunabout wrote: ↑Fri Dec 09, 2022 11:42 pmThe trim piece Mike has isn’t the right one it is a stamped with a small flange.
Part found, Thanks Frank.
