FS—-> Transmission Drums.
Posted: Tue Dec 13, 2022 2:59 pm
Just took this transmission apart I’ve had stored for many many years. Most parts needs cleaning up.
I have the brake drum (not cleaned up) yet. $200
Reverse drum, $200
Low speed drum. $200
Gear shaft. $55.
Driven Gear. $45.
Riveted Triple gear set/3.$100
Driven plate and clutch push ring. $50.
Clutch disc drum. $20.
Flywheel and magnets. $50.
Condition: I see no visible cracks on reverse and low speed drums only a couple of small nicks on the edges, the brake drum appears to be in very good shape also with minimal wear on the clutch lugs. In fact there’s not much wear on any of the bushings everything was tight without any sloppy movement.
Text or call 423-2eight4-97fifty.
Reverse drum, $200
Gear shaft. $55.
Driven Gear. $45.
