OT: Stromberg OD-1 carburetor part needed choke part
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Dec 30, 2022 12:30 pm
Know you guys have "other" stuff in your collection so thought I would ask here too.
Looking for the elbow(s?) that holds the choke and is mounted to main body of a made for Dodge Brothers Stromberg OD-1 carb. The mounting holes would be approximately 1-7/8" center to center. I was hoping the part from my OS-1 would fit but was too wide. While there are 4 holes showing, the mount only uses 2. At this point I would be happy with just the elbow the choke mounts in with butterfly. Assembly #P8712 in the drawing.
1920 Dodge touring
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: OT: Stromberg OD-1 carburetor part needed choke part
Post by Bruce Compton » Fri Dec 30, 2022 11:16 pm
Mark : Check with Russ Potter as he ended up with a big box of Stromberg parts (OF and other models) from the Stan Howe auction.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sat Dec 31, 2022 11:23 am
Thank you. Will definitely give that a try.
1920 Dodge touring
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Wed Feb 01, 2023 3:10 pm
Bump back to top
1920 Dodge touring
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue Mar 21, 2023 10:09 pm
30+ days bump :)
1920 Dodge touring
