What is this headlight rim used on?
RandyB
First Name: Randy
Last Name: Behrens
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
MTFCA Number: 8006
MTFCI Number: 22868
Post by RandyB » Thu Feb 02, 2023 11:41 am
I bought this rim at a swap meet for my Model T shortly after getting into the hobby. I thought it was a T headlight rim until noticing differences with a T rim. This one has a 9-1/8" diameter rather than the 9" diameter on a T headlight rim. There are also 4 steel pads on the outside of the rim, equally spaced. Does anyone know what this is used on?
MTFCA Number: 14972
MTFCI Number: 15411
Re: What is this headlight rim used on?
Post by RajoRacer » Thu Feb 02, 2023 12:35 pm
Has Ford script so have to assume it WAS for a T that someone modified.
RandyB
First Name: Randy
Last Name: Behrens
MTFCA Number: 8006
MTFCI Number: 22868
Post by RandyB » Thu Feb 02, 2023 3:19 pm
I think you’re correct. I held the back side up to bright light and it appears there are indications that cuts were made between at one of the outside steel pads. They did a decent job of hiding their modification. Thanks for your response.
MTFCA Number: 51486
Post by TXGOAT2 » Thu Feb 02, 2023 3:51 pm
Could it be for a military application requiring some kind of blackout shade or wire screen to protect the lens?
Post by TRDxB2 » Fri Feb 03, 2023 1:10 am
There are no clips on the inside of the rim to hold a lens in place.
RandyB
First Name: Randy
Last Name: Behrens
MTFCA Number: 8006
MTFCI Number: 22868
Post by RandyB » Fri Feb 03, 2023 7:15 am
I passed it around at the T club meeting last night. No guesses as to what its use was. If it had been modified in the past, the rim showed no tool markings on the inside of the rim where it might have been welded and ground down. I’m just curious enough to see what’s under the paint. Thanks for the replies on the headlight rim.
