A crankshaft / T block mainbearing mold
Topic author - Posts: 849
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Babbitt bearing mold to pour mainbearings in model T block when installing a Model A crankshaft or crankshaft with similar diameter mainbearings … will pour block and caps at 1 1/2" diameter to allow for finish machining … price is $125.00 + $13.60 flat rate priority mail postage in lower 48 states ...actual postage outside this area or international … Gene French 970-581-2808
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
Re: A crankshaft / T block mainbearing mold
to the top again , thanks MTFCA
- First Name: Gene
- Last Name: French
