ROADSTER TOP IRONS WANTED
Posted: Sun Feb 19, 2023 2:23 pm
by tom_strickling
Still looking for top irons for a 24 roadster.
Re: ROADSTER TOP IRONS WANTED
Posted: Sun Feb 19, 2023 6:23 pm
by CudaMan
Folks call the different parts different names. By irons do you mean the forged parts that mount to the body that the top sockets pivot on? Here is a pair that is currently on Ebay, I have no connection to the listing or the seller.
https://www.ebay.com/itm/225275815765?h ... R-SUsr_NYQ
If you mean the sockets and bows, these are not cheap, but available. I have no connection to the listing or the seller.
https://www.ebay.com/itm/325538258710?h ... R-SUsr_NYQ
Posted: Mon Feb 20, 2023 9:17 am
by CudaMan
If you need prop nuts, top saddles/pads, or the rods that the saddles slide onto, Lang's website shows them all, I don't know if they are in stock or not, you'd have to call and ask them.
https://www.modeltford.com/item/3314XN.aspx
https://www.modeltford.com/item/3858B.aspx
https://www.modeltford.com/item/3314CX.aspx
If you need the brackets that fit inside the rear corners of the body that the saddle rods screw into, there is a pair on Ebay:
https://www.ebay.com/itm/155369777781?h ... R-zI7_LNYQ
Posted: Mon Feb 20, 2023 7:34 pm
by CudaMan
Posted: Mon Feb 20, 2023 7:40 pm
Those appear to be for '26 - '27 - they have a slight curve where they bolt to the body - earlier irons (the correct ones) are straight there.
Posted: Mon Feb 20, 2023 8:34 pm
by JTT3
Even the ones in the link to eBay are not right. The pivot socket & middle socket are correct but the sockets that connect to the windshield are incorrect. No curve where they attach to the pivot socket.
Posted: Mon Feb 20, 2023 8:48 pm
by CudaMan
I wondered about that, looking at my 1924 sockets revealed them to be straight, as you mentioned. I should have looked at the pictures more closely instead of taking the sellers' descriptions at face value.
Posted: Mon Feb 20, 2023 9:19 pm
by tom_strickling
Thanks all.
I do mean sockets and bows Mark.
