Speedo parts for sale
Posted: Sat Feb 25, 2023 11:30 pm
by Larry LaPatka
Excess for my needs speedo gear and plate.
Both for $75.00 plus postage.
Thank You
Re: Speedo parts for sale
Posted: Sun Feb 26, 2023 12:35 am
by Mark Gregush
The top one is for AC setup and bottom one looks to be for Stewart. Because we cannot click on the images for bigger view, maybe more information would be in order esp on the No 2.
Posted: Sun Feb 26, 2023 9:30 am
by Russ_Furstnow
The second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow
Posted: Sun Feb 26, 2023 4:28 pm
by ModelTWoods
Also, the first top gear, which is an AC is for wooden wheels only. A different gear, made exactly the same except a fourth tab and mounting hole were added, was used with wire wheels.
Posted: Wed Apr 12, 2023 9:56 pm
by electfearless
The second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow funny shooter 2
Is it still available for sale?
