Cam bearings
Posted: Tue Mar 14, 2023 12:18 am
by BarrettR
Hey guys, does anybody pour babbit in old cam bearing shells? I know new ones are available from langs but I heard they don't fit well without repairing.
Re: Cam bearings
Posted: Tue Mar 14, 2023 3:03 am
Try asking on the general forum, not here in the classifieds.
Re: Cam bearings
Posted: Tue Mar 14, 2023 12:51 pm
by Joe Bell
Take a hose clamp and tighten old shell, fill it with babbitt, set it in the lathe and bore to size, it is no rocket science on them.
Re: Cam bearings
Posted: Tue Mar 14, 2023 4:43 pm
by Dan McEachern
Before you go to that trouble, clamp them together and make sure the OD is somewhere near 1.375/1.373. Old shells are not worth repouring if the parting lines are worn down, making them loose in the block.
Re: Cam bearings
Posted: Tue Mar 14, 2023 9:21 pm
by BobShirleyAtlantaTx
Make sure the break in the iron shell looks like a fresh break and is not worn smooth. The little jig is not hard to build.
Re: Cam bearings
Posted: Wed Mar 15, 2023 7:00 am
by Joe Bell
As Dan said you do want to start with good shells.
