FS EDITED POST with PICS Speedster Parts sold
Posted: Wed Mar 29, 2023 11:38 am
Everything you need to turn your standard T chassis into a speedster . small drum Ruckstell rear end , shifter shaft and gear shaft handle used but in good condition , I boult it from Mark Chaffin . aluminum Warford with shortened radius rods and drive shaft rebuilt by Henry K Lee . He is the best . steering column with lower gear box , coupler , connection rods fatman steering wheel really cool looking . . I all so boult from Lee . He told me that this column is very versatile .the gear box can be swiveled . Rear springs with reversed clevis hole , rear crossmember to move rear springs forward .original parts to lower the rear axel . 1926 -27 front springs with reversed clevis holes , original period front spindle drops to lower the car front end ,1926-27 wheel spindles . ignition switch with off on bat mag head lights ,Very cool accelerator petal and rods that connect to the carb . I have lots of Model T parts if you need something . 50 years worth . everything listed for the very low price of 3500.00 I can send pictures from my phone to your phone . Thanks Perry 512 234 0243
