Good parts see listing
Posted: Sun Jan 13, 2019 12:55 am
11-14 front timing gear motor cover felt in casting- $40
15 set front fenders decent painted $150
Unknown rear fender set but T $90
Set splash shields decent black era $40
Set running boards 13-25 $50
17-22 windshield frame no hindges$40
19-25 ignition switch assembly w key $25
15 hood former modified to look like 11-14 $40
15 hood rough but usable $40
11-15 wood hood shelves oak? $25
C-R-B pedal set wear on letter shaft should be ok $85 for the set
Brass Ford script Ford radiator $45
09-15 aftermarket brass radiator unknown condition honey comb style core
Brass top tank steel sides looks AS IS $150
17-25 headlight buckets metal solid usable $5
Newly made speedster seats (pair) similar to rootlieb $125
Starter switch $10
Brass hub fan bent arm brass (repo) and bolt center shaft on modern bearings $75
Set sidelight bracket 11-14 $50
Set oil side lights non ford but similar to 17-25 style but use the 11-14 brackets $65
Hand wiper new in bag $10
1 TT rim clamp $10
30x3.5 rim no sharp edges lug little wear usable $45
Home made Jack windshields glass $25
All plus shipping make offers can send pics
Starter switch $10
1 TT rim clamp $10
