Wanted 1913 Touring top iron
Topic author - Posts: 5
- First Name: Russell
- Last Name: DeCrease
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1923 Runabout
Please help …. I need only the drivers front iron for a 1913 Touring (the one that attaches to the windshield).
Please, please, please … I’m topless without it (and believe me, that’s NOT an image you want to see on tour)
Russ
Russ
- MTFCA Number: 52564
Re: Wanted 1913 Touring top iron
You mean the body iron the socket/bow mounts to? The only connection between the header bow and windshield might be a strap.
1920 Dodge touring
1920 Dodge touring
Russ, do you mean the stay between the windscreen hinge and the top of the body?
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
- MTFCA Number: 29375
I might have what you need show a picture of the passenger side and that way we will be able to see what you need
- MTFCA Number: 121
- MTFCI Number: 16310
Try John Boorinockis in Auburn, California. He makes identical sockets. If you can find him, he could use the parts off your old one.
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
- MTFCA Number: 8377
- MTFCI Number: 22437
Try Mel Draper of Mel's leather and horsehair. He made the tip socket for my '12.
Thank you all for the replies. I misspoke when I said attaching to the windshield, it attaches from the front most iron to the front bow (which attaches to the windshield via a strap). The attached picture is of the passenger side, but am looking for the drivers side (which is not intact). Although I am new to this, searching this forum I have found reference that these "front extension" bars are unique to 1913 because that iron is 26" long and other years are 23" (I have only found one reference to this)
- MTFCA Number: 14383
If this is your T, It appears to be a !4. Short doors & W/S folds inward. If 13 is unique for the iron you need, this will matter.
That is the T in question and I “believe” it to be a 1913 based on the serial # and title (we all know how much that means). The forum thread I saw mentioned a difference in length (IE 1915 were shorter). From that post I am unsure if the 26” length mentioned is 1913 or 13&14.
- First Name: Tom
- Last Name: Rootlieb
- MTFCA Number: 440
13/14 top sockets are the same. I would think you could get that single socket from John Bornakis.
Thank you for the John Boornakis in Auburn CA recommendations. I have attempted to reach him a couple of times this week based on the number I found on this forum but will continue to try (there is no voicemail on the number I have).
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
- MTFCA Number: 875
- MTFCI Number: 2519
What is the length of the front top socket for the 13/14 t's? I purchased a set of top sockets for my 14 Roadster quite some time ago and the front socket measures 20" long. Thank you Craig
- Last Name: Gagel
I bought the same top iron from Mel. It was a perfect fit. It's well worth the phone call.
- Last Name: Gagel
Sent email
I believe the mam"s name is spelled Boorinakis. I could be wrong, like the other three attempts.
The short doors and the dogleg in the windscreen stays would indicate a 1914 model but that socket is the same as a 1913 anyway. The 1915 onwards socket was shorter because the windscreen was set further back on the new cowl.
Hope this helps.
Hope this helps.
You should ask for the socket, not top iron. For Model T's, the top irons are what the top mounts to on the body.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 121
John Boorinakis. 530-401-7777. 545 Dairy Road, Auburn, California 95603
