I would like to buy four number 777 valve stems for my 30X3.5 tubes.
I think that they will fit through the hole in the wheel.
The rubber stems on my new tubes don't.
WTB metal valve stems
- MTFCA Number: 121
- MTFCI Number: 16310
Re: WTB metal valve stems
You shouldn't have a problem. They oftentimes show up at swap meets. Keep in mind that Schrader is not the only company that made them. Dill and Bridgeport also made them.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Check out Larry (Original) Smith's article on metal valve stems in the latest MTFCI "Model T Times" issue!
John, 888 stems are the same size, but I believe a little longer. This may widen the field for you. I have just fitted two 888 stems to tubes for my own use.
Hope this helps.
Hope this helps.
Schraeder 777s are about 1/4 inch longer than 888s.
Thanks Mark. I knew they were a different length, but not which way.
Topic author - Posts: 132
- Last Name: Cox
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
I would be happy with the 888 or 777.
My car is a 15 so I would prefer the knurled parts.
Any one out there willing to sell me four sets?
