WTB Hershey hunting list
Posted: Sun Sep 10, 2023 4:59 pm
I will be on the hunt for these items for a 1926 Tudor at Hershey.
Driver side rear radius rod
Rear axle rebuild parts
Ruckstell axle or parts to convert axle I have
Modern driveshaft spool bearing kit
Driveshaft
Axle shafts
Hyatt axle bearings
U-joint
Sheet metal parts lower part of car
Cowl-door-quarters-rear-corners-rear panel
Subframe cross member under rear seat
Running boards
Firewall
Outer Windshield frame
Tudor safety glass
21” splitrim
New Wood spokes
Tail lights
Bosch distributor parts (front plate type)
Model T tools
King pin reamer .502
Stevens ream fixture
Drive shaft front bush facing reamer
Axle sleeve puller
Regan wheel press
And about 1000 other things
Bryant
Driveshaft
Axle shafts
Hyatt axle bearings
U-joint
Running boards
Firewall
Tudor safety glass
21” splitrim
New Wood spokes
Tail lights
Model T tools
Axle sleeve puller
Regan wheel press
Bryant
