LOOKING FOR WTB GAS TANK SEDIMENT BULB OUTLET FLANGE
Topic author - Posts: 495
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
- MTFCA Number: 49646
I am needing for an oval tank 1920ish, the bottom treaded flange for the sediment bulb to screw into. Mine is missing. If you have an old tank the is bad and the part is good, I would be interested in it. Especially if you can cut about 2 inches or more away from it so I can use it as a patch and have something to weld to. I then can save this tank for to be used, that is all that is wrong with it.
1924 Model T Touring
1924 Model TT Truck
1930 Model A Pheaton
1924 Model TT Truck
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: LOOKING FOR WTB GAS TANK SEDIMENT BULB OUTLET FLANGE
Let me go and check in the barn, I think I have one left!
Hank
Hank
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
i had sent an email i have one im looking at
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Sorry for not replying back sooner. Only had one attached to a complete tank.
Hank
Hank
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Anyone know where you would find the inlet & outlet castings if one where to try making a new gas tank? Hank didn't you know the Gentleman that was making the tanks?
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
If you don't have to have original, they are 1/2 pipe thread. Any plumbing store has 1/2 inch pipe threaded screw plates about 3 inches in diameter.
Or find a piece of brass or copper --- which is what I would do -- 1/4 inch thick, drill and tap it 1/2 inch pipe and solder it on to the tank.
Thanks Stan
1924 Model TT Truck
1924 Model TT Truck
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Steve I have brass bungs but they are not original but work fine.
Email is acting up, you can call me at four 2 three ate 3 seven 57O nine.
Hank
Hank
