Deleted add
Posted: Wed Nov 01, 2023 4:50 pm
by WaltM
Deleted add
Re: Wanted Three Rajo Rocker Arms and Valve Cover
Posted: Fri Nov 03, 2023 9:44 am
by WaltM
to the top
Posted: Mon Nov 06, 2023 11:37 am
by WaltM
Back to top
Posted: Mon Nov 06, 2023 2:54 pm
by kmatt2
Walt, I can’t help you with any extra rocker arms for a Rajo Model 30 commercial head, but a few years ago I was able to buy a rocker arm cover for a Model 30 head from Dan McEachern . The only difference in the commercial head cover is that the commercial head has a shelf for short head bolts on the valve port side , their for the cover doesn’t need to clear a head bolt. A standard Rajo cover will work if don’t mind another place to leak rocker oil from the felt pad.
Posted: Tue Nov 07, 2023 7:33 am
by WaltM
Kevin, thank you for your reply and information. I will follow up with your lead. Thanks again, Walt
Posted: Tue Dec 26, 2023 1:57 pm
by WaltM
To the top
Re: Wanted Three Rajo Rocker Arms Model 30
Posted: Fri Jan 05, 2024 4:44 pm
by WaltM
Looking for Rajo rocker arm to match the ones in the photos. Thanks, Walt
Posted: Sun Jan 07, 2024 6:15 pm
by WaltM
To the top
Posted: Mon Jan 08, 2024 4:39 pm
by Southfork Creek
If you are tired of waiting for an original, try Rocker Arms Unlimited in California, phone 530-242-1316, website
www.rockerarms.com
They built a set for my Rajo C35. If you have one to send them, then likely you will be in good shape.
Posted: Thu Jan 25, 2024 2:50 pm
by WaltM
to the top
Posted: Thu Feb 01, 2024 2:11 pm
by WaltM
To the top
Posted: Mon Feb 19, 2024 12:22 pm
by WaltM
to the top
Posted: Tue Feb 27, 2024 2:02 pm
by WaltM
Still Looking for three original rocker arms.
Posted: Fri Mar 15, 2024 12:42 pm
by WaltM
Back to the top. Thanks, Walt
Posted: Tue Mar 26, 2024 3:54 pm
by WaltM
Still looking, Thanks, Walt
