Body moldings
Posted: Fri Jan 05, 2024 1:35 pm
by Steves Ts
WTB Outside body moldings for a 1914 Ford Model T Roadster. These moldings mount on the back of the body and "curl" down following the lines of the turtle deck just below the deck. The moldingd appear to be solid steel and mounted on the body via screws. any help would be greatly appeciated
Re: Body moldings
Posted: Fri Jan 05, 2024 2:30 pm
by Tbird
Steven,
I can’t speak with knowledge on a 1914 moldings, however the steel moldings you are talking about are probably done the same as the ones on my 12 delivery car moldings. They are 3/4” half oval steel and about 3/16” in height. Easy to heat and bend yourself. If you have a steel supplier near by they usually stock something like that. I live in Elkhart which is the trailer capital of the US, so there are lots of steel suppliers near me.
Re: Body moldings
Posted: Fri Jan 05, 2024 6:46 pm
by Steves Ts
Hi Mike, Thank You for Your reply. Yes You would be right on the description of the moldings. I was hoping to find set so as not go through the headache of trying to manufacture. I will have to learn how to be a Blacksmith !! LOL
Re: Body moldings
Posted: Fri Jan 05, 2024 9:36 pm
by Runabout
Restoration Supplies used to carry moldings, I haven’t seen their catalog in several years so it’s worth checking with them.
Re: Body moldings
Posted: Sat Jan 06, 2024 12:21 am
by Tbird
love1913 wrote: ↑Fri Jan 05, 2024 6:46 pm
Steven,
All part of the joy of the hobby!
Re: Body moldings
Posted: Sat Jan 06, 2024 10:15 am
I bought some of the body moulding material from McMaster Carr for my 1919 Roadster. They were almost duplicate of the originals size and the oval shape. That was several years ago and they still might carry them. They were listed under moulding materials if I remember.
I used a acetelyne torch for heat to shape them. Wasn’t that hard to do.
Re: Body moldings
Posted: Sat Jan 06, 2024 8:29 pm
by Steves Ts
Thanks John and Steve for Your help !! Ill check out both ideas
Re: Body moldings
Posted: Sun Jan 07, 2024 10:30 am
by Russ_Furstnow
The body moulding on a 1914 is one piece. Here is a photo of the moulding on a Wilson body 1914 runabout
Re: Body moldings
Posted: Sun Jan 07, 2024 11:32 am
by Art Ebeling
Ty his is the body that came with my 14 project. It is different than what Russ has. I do not know how to determine the body manufacturer. Any thoughts ? Art
Re: Body moldings
Posted: Sun Jan 07, 2024 12:05 pm
by Russ_Furstnow
On many 1913-14 bodies, there is a letter stamped into the kick plate in front of the gas tank. The 1914 body pictured has a "W" stamped into the kick panel and a "W" stamped into the wood frame that supports the seat springs. Also note the Wilson rear body panel is one piece and goes from the the top of the body to beneath the turtle deck.
Re: Body moldings
Posted: Sun Jan 07, 2024 12:06 pm
by Russ_Furstnow
Here is the "W" stamped into the kickpanel.
Re: Body moldings
Posted: Sun Jan 07, 2024 2:47 pm
by Art Ebeling
Thanks Russ. Mine is B.
Re: Body moldings
Posted: Sun Jan 07, 2024 7:00 pm
by Steves Ts
Thanks Russ and Art for Your replies. I am going to try and replicate the moldings on Russ's '14 . Still hoping to find a "set" that is" pre-molded". Great pictures Guys !
Steve
Re: Body moldings
Posted: Sun Jan 07, 2024 7:05 pm
by Steves Ts
One last question, what type of material was used to fill in the screws ?
Re: Body moldings
Posted: Sun Jan 07, 2024 7:22 pm
by Tbird
love1913 wrote: ↑Sun Jan 07, 2024 7:05 pm
My understanding is to use solder.
Re: Body moldings
Posted: Sun Jan 07, 2024 7:40 pm
by Steves Ts
Thanks Mike, that would make sense considering "in the day" They used lead for body fillers (no plastic fillers then)
