Spiral wound rear axle roller bearings SOLD
Posted: Fri Jan 05, 2024 7:17 pm
Rear axle roller bearings for Model T cars part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers.
