Fs ruckstell parts pile
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
MTFCA Number: 52955
Board Member Since: 2022
Post by Karl Von Neumann » Wed Jan 10, 2024 5:27 pm
Ruckstell parts just about a whole diff here the housing would need work need a tube. The guts are decent used the sliding clutch shows wear as well as the stock side of the carrier. Bearing needs replacing $800 plus the ride from pleasant prairie wisconsin or local pickup.
Would consider trading for 1913 parts building a speedster going to need alot of smalls and specific stuff
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Re: Fs ruckstell parts pile
Post by Ken Buhler » Thu Jan 11, 2024 12:51 am
Hello Karl,
A Ruckstell needs to be precise and tight. It can be very costly to build a dependable one. I have five Ruckstell gear carriages apart on my bench and I am using micrometers and calipers to determine the precise measurements of each part so that I will know which parts to replace. Looking at what you are showing is like looking at a car going by in a parade. If you could provide measurements of the critical wear areas, it would be helpful.
Work honestly
Stay true to your word
Get the job done right
Karl Von Neumann
First Name: Karl
MTFCA Number: 52955
Post by Karl Von Neumann » Thu Jan 11, 2024 10:19 am
Ken if I had bule print or measurement I would be able to post that's info I also have several ruckstells I'm going thru as well
Karl Von Neumann
First Name: Karl
MTFCA Number: 52955
Post by Karl Von Neumann » Wed Jan 24, 2024 11:01 am
Move to top
Karl Von Neumann
First Name: Karl
MTFCA Number: 52955
Post by Karl Von Neumann » Wed Feb 07, 2024 4:36 pm
Move to top
Karl Von Neumann
First Name: Karl
MTFCA Number: 52955
Post by Karl Von Neumann » Mon Feb 12, 2024 8:29 pm
Move to top
