Fs ruckstell parts pile
Posted: Wed Jan 10, 2024 5:27 pm
by Karl Von Neumann
Ruckstell parts just about a whole diff here the housing would need work need a tube. The guts are decent used the sliding clutch shows wear as well as the stock side of the carrier. Bearing needs replacing $800 plus the ride from pleasant prairie wisconsin or local pickup.
Would consider trading for 1913 parts building a speedster going to need alot of smalls and specific stuff
Re: Fs ruckstell parts pile
Posted: Thu Jan 11, 2024 12:51 am
by Ken Buhler
Hello Karl,
A Ruckstell needs to be precise and tight. It can be very costly to build a dependable one. I have five Ruckstell gear carriages apart on my bench and I am using micrometers and calipers to determine the precise measurements of each part so that I will know which parts to replace. Looking at what you are showing is like looking at a car going by in a parade. If you could provide measurements of the critical wear areas, it would be helpful.
Posted: Thu Jan 11, 2024 10:19 am
by Karl Von Neumann
Ken if I had bule print or measurement I would be able to post that's info I also have several ruckstells I'm going thru as well
Posted: Wed Jan 24, 2024 11:01 am
by Karl Von Neumann
Move to top
Posted: Wed Feb 07, 2024 4:36 pm
by Karl Von Neumann
Move to top
Posted: Mon Feb 12, 2024 8:29 pm
by Karl Von Neumann
Move to top
Posted: Tue Apr 30, 2024 12:39 pm
by Karl Von Neumann
Move to top
Posted: Sat May 25, 2024 12:17 pm
by Karl Von Neumann
Move to top
Posted: Sun May 26, 2024 8:30 pm
by RGould1910
Just a suggestion Karl. You dont need blueprints or original specs. If you have a dial caliper, measure the wear aeas and report. Yiou'll have better responses I think.
