WTB: Cowl Light mounting brackets to wood cowl.
Posted: Sat Jan 27, 2024 1:45 pm
by signsup
Creating this WWI ambulance and mounting the cowl lights on a flat wooden dash/firewall/cowl and looking for two brackets to do so. Had used two on another wooden dash project vehicle that bolted to the wood and then the cowl light bolted to the bracket. Looking for two, maybe three if I decide on a single tail light with no license plate frame.
Let me know if you have something and what you want. Should fit in small or medium USPS priority flat rate box for $15.
Thank you.
Re: WTB: Cowl Light mounting brackets to wood cowl.
Posted: Mon Jan 29, 2024 7:42 pm
What type of lamps are you going to use ? Makes a difference in the style of bracket.
Posted: Wed Jan 31, 2024 6:39 pm
by signsup
These are my proposed lamps. Its' what I have on the shelf right now. One has the castle nut and hole in the rod for the cotter pin and one just has a threaded rod bolt and nut. But came off same win
Posted: Sat Mar 30, 2024 8:58 am
by Karl Von Neumann
I think I have one flat cowl mount
Posted: Sat Mar 30, 2024 12:10 pm
by George House
You mean like these ???
Posted: Sat Mar 30, 2024 6:32 pm
by signsup
George, yes, exactly like that. Unfortunately, I forgot that I had this thread out here and have changed the design of the firewall and cowl so that I no longer have a flat surface to work with. The cowl I have created is sloped towards the front and I now need to fabricate some sort of straight strip that will come flat out from my dash panel and allow me to mount a forward facing cowl light to it. So, no right angles in it at all. Just mounting holes and a single cowl bolt hole on the same plane.
