WTB: Front Axle Spring Perch for 1913 Passenger Side
Topic author - Posts: 343
- First Name: Darren
- Last Name: Wallace
Title says it all, looking for a correct one that is in decent shape. This is the one with the wishbone hole above the axle. Many thanks in advance!
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
- MTFCA Number: 443
- MTFCI Number: 23136
Re: WTB: Front Axle Spring Perch for 1913 Passenger Side
I might have one I can part with, will have to check which side it is.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
Darren, do you mean the right side? I may also have one, but Chris is closer.
Hi Allan, Yes, if you're looking at the front of the car from out in front of the car, and looking at the left side, that's the spring perch I need.
To add to the confusion, my car has Hassler shocks on it so in order to use them, both the spring perches must be turned around 180 degrees, and then the entire axle has to be turned around as well so the angle for the axle's camber is correct. So in my case, the passenger side spring perch is in fact on the driver's side.
Darren, there's no confusion if you stick to left or right side. US cars are left hand drive, i.e. the steering wheel is on the left side. They do not become RHD when you look at the car from the front, or the side for that matter.
Hope this avoids confusion.
Found one, thanks everyone!
- MTFCA Number: 52564
You don't turn the axle you swap the perches as well as turn them. It is the perches that set the angle not the axle. If you turn the axle you also have to swap the spindles.
1920 Dodge touring
1920 Dodge touring
