sale pending FS- New Set of Valve Multilifts
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Feb 09, 2024 8:51 pm
For sale- complete, new, never installed set of valve multi-lifts. These are no longer produced and are hard to find. This is a set made by Jerry Hunt many years ago. Includes all installation hardware. Jerry did a great job on these- investment cast and hardened levers etc. Price is $400.00 shipping USPS or UPS additional at cost. PM or e-mail dmcgearsATyahooDOTcom. Thanks
You do not have the required permissions to view the files attached to this post.
Last edited by Dan McEachern on Sun Feb 11, 2024 1:59 pm, edited 2 times in total.
Craig Leach
First Name: craig
Last Name: leach
Re: FS- New Set of Valve Multilifts
Post by Craig Leach » Sat Feb 10, 2024 12:02 am
Hi Dan,
I have a set of these that I will set up someday & have ideas on making them more securely installed & taking some steps to reduce wear from
the small contact area of the valve stems. I have never seen the parts in the upper corners, I assume they are for a more dispersed secure hold
down. They look impressive something you came up with?
Craig.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Feb 10, 2024 12:22 am
Hi Craig- not sure of the different style hold downs, but they seem more robust than the single long hex hold downs that are on the multilifts in my pictures. I'm assuming they might be an improved hold down design. The block part sits transverse across the lower frame/body and the discs contact the roof of the valve chamber and have circular grooves on the block side that are intended to dig into the block slightly to prevent any movement. ITs a pretty slick "improvement".
Dan
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Feb 10, 2024 12:24 am
oops- double post- sorry !!!
Hi Craig- not sure of the different style hold downs, but they seem more robust than the single long hex hold downs that are on the multilifts in my pictures. I'm assuming they might be an improved hold down design. The block part sits transverse across the lower frame/body and the discs contact the roof of the valve chamber and have circular grooves on the block side that are intended to dig into the block slightly to prevent any movement. ITs a pretty slick "improvement" if you ask me.
Dan
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Feb 10, 2024 1:44 am
Hi Dan,
I would say so, I would love to see more as the hold downs seem to have been a issue for some & that looks like the answer. I also planed on putting valve lash caps on the valve stem spread the load out on the levers.
Craig.
Dan McEachern
First Name: DAN
Re: sale pending FS- New Set of Valve Multilifts
Post by Dan McEachern » Sun Feb 11, 2024 1:59 pm
these are sold pending payment- thanks all.
RichardW
Last Name: Williamson
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by RichardW » Sun Feb 11, 2024 2:35 pm
If those sell, I also have a set just like those, that are available
Richard
Marc Roberts
First Name: Marc
Last Name: Roberts
* REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Touring
Post by Marc Roberts » Sun Feb 11, 2024 7:20 pm
I have never seen these. What do they do?
Post by RajoRacer » Sun Feb 11, 2024 8:37 pm
Add additional valve lift.
