The best carburetor shut off valve you'll ever buy - more assemblies ready soon
Posted: Thu Feb 29, 2024 3:37 pm
- Nickle plated brass ball valve (made in Italy) that due to it's construction, has the best throughput of any valve available
- all brass construction of USA made fittings - NO COPPER line to fatigue or damage when tightening onto the carb (the removable connection is a double-ferrule design which is an industry standard industrial fitting designed to not over-compress or otherwise damage tube)
- all industrial fittings - no cheap hardware store junk to be found here
- assembly fits standard Model "T" fuel line nut and packing - is a drop-in replacement for your leaky carburetor valve
- simple 90 degree twist to shut off fuel
- will NEVER need fiddling, farting around, or expensive lube to seal correctly - valve body is brass, valve seat is PTFE and stem seal is Viton
- no risk of accidental fuel spills beyond a few drops when disconnected - when removing the carb, the valve STAYS WITH THE FUEL LINE, not the carb
- no parts to lose when disconnecting carb for service - hardware stays on fuel line, while elbow stays on the carb
- not a cheapy assembly, but very high quality industrial parts are used throughout, so priced accordingly - if you want cheap, look elsewhere and invest in an extra fire extinguisher
Due to cost of components and the need to fabricate 1 part which no one makes other than myself, I will not stock excessive inventory and will simply build to order
first one will be available in about 3 weeks after I finish my annual run of Full Flow Float Valves
Thank you for looking
EMAIL for information
Re: The best carburetor shut off valve you'll ever buy
Posted: Thu Feb 29, 2024 4:11 pm
by John A Kelso
Can you price this for me please, Thank you.
Posted: Fri Mar 01, 2024 12:44 am
by Burger in Spokane
I love the idea of making high quality parts, but this part is
as modern looking as it could possibly be. Is it possible to make
this with bulbed hubs/castings/handle to look appropriate on a
1920's machine ?
Posted: Fri Mar 01, 2024 4:29 am
Some are so Teed off with the other types of shut-off valves available that they would put up with the modern looks of this one, but i understand where you are coming from Brent. Given a brass handle and some tarnish on the new fittings, it would not look so out of place after a while.
I'm guessing Scott has had to make the brass fitting to which the T fuel line packnut screwed. Given the origin of the valve, it is likely a metric thread.
Posted: Fri Mar 01, 2024 12:32 pm
I prefer to see the one Langs has sold for years. If it was made once, it can be made again.
Posted: Fri Mar 01, 2024 1:24 pm
by George House
It appears hideous when on a tour with the hood open. But I’m extremely glad to see you back Scott
Posted: Fri Mar 01, 2024 5:31 pm
by Ed Fuller
Nice work Scott! A great solution to a much needed part!
Posted: Fri Mar 01, 2024 6:52 pm
by Larry LaPatka
No, hideous to me is watching your vehicle burning due to a nice looking part that developed a leak, and if parked in your garage watching it going up in smoke too. Kissing a horse on it’s butt hole doesn’t cure chapped lips but it sure as hell will keeping you from licking them again any time soon!
Posted: Sat Mar 02, 2024 1:03 pm
by John A Kelso
The horse part gave me a good laugh, made me smack my lips, thanks
Posted: Sat Mar 02, 2024 1:21 pm
Larry LaPatka wrote: ↑Fri Mar 01, 2024 6:52 pm
Larry,
I am at a loss as to how that applies here, but it does appear to be sound advice that I will follow in the future. Thank you sir!
BTW, nice part Scott! Quality as always!
Posted: Thu Mar 07, 2024 12:02 pm
by mbowen
Anything (or nothing) would be better than what my ‘24 touring came to me with. The far right side of the passenger floorboard had been modified to easily access the pictured valve which in hindsight I’m not even sure was intended for liquid fuel. A few months after I bought Bonnie I came home from about 3 days away to find an extremely strong odor of gas in the garage and hangar, and an empty tank on the T. I feel fortunate to have not lost my home.
Posted: Thu Mar 07, 2024 1:27 pm
by bdtutton
Scott....I don't have a shut off valve by my carburetor, but I have been thinking about putting one on my car because it does drip a drop or two a day and my wife hates the slightest smell of gasoline in the garage. I do shut the valve on the bottom of the tank when I store the car so it is not a problem in the winter, but I think I would like to have one of these. How much??
Posted: Thu Mar 07, 2024 1:30 pm
by mtntee20
FYI Valves should have a rating, right on the body but it might be in the paperwork. "W O G" No, it's not a reference to any animal. Water, Oil, Gas. Gas is NOT gasoline! Gas is the vapor type such as Air, propane, natural, etc. There should also be a pressure rating, though this in not a significant concern to Model T people as the pressure is near zero unless a fuel pump is being used.
The valve in the photo above, appears to be for natural gas, used as a supply shut off to a water heater most likely. It appears to be a bit small for a gas furnace but could be used there as well. I seriously doubt it has a rating for "oil" as in gasoline.
Now, armed with this info and $25, you can buy a cup of coffee at Starbucks.
Posted: Fri Mar 08, 2024 1:16 pm
To those who have shown interest here, on the forum, please notice Scott's contact preference, "EMAIL for information"
Posted: Mon Mar 18, 2024 9:23 am
by Herb Iffrig
Could this be hidden near the gas tank, say on a Torpedo roadster?
Posted: Wed Jun 12, 2024 10:42 am
Round Two
This allows you to shut off your fuel and remove the carb for servicing without any hassle or spilled gas.
The first ones went quickly and I have a few remaining
INQUIRE VIA EMAIL - I DO NOT MONITOR THIS FORUM
thank you
Posted: Wed May 21, 2025 11:56 am
I am putting together parts for a 1/2 dz more assemblies
If you are interested, please email me
thank you
Re: The best carburetor shut off valve you'll ever buy - more assemblies ready soon
Posted: Fri Aug 08, 2025 4:52 pm
by DHort
The hardest part of putting something like this together is the only info provided is go to a hdwe store. No on specifies if it is Ace, True Value, or Menards. No one includes SKU or UPC code. Standard or NPT? Any of that info would help.
Posted: Sat Aug 09, 2025 9:59 pm
by DaveBarker
I'd also be interested but need to know the inlet-output thread sizes. My fuel system isn't standard.
Gas shut off
Posted: Tue Aug 12, 2025 5:31 pm
by laltenhofen
Got any of these left. Cost? If so, and i décide on one, maybe I can get a break on freight tied in with float valve. Do you run with the Montana 500 crowd? I'd would like to tag along behind-not racing- up there next year.
