Accessory Stromberg choke control
Dropacent
Last Name: Morsher
Post by Dropacent » Thu May 30, 2019 5:21 pm
:shock: I have these ready to ship.
A couple of folks have changed their mind or not ready for one, so I do have several extra available right now. These new controls have a SS flat wound Bowden cable covered in black vinyl and will blend in better on a black steering column. Makes an accessory carb such as the Stromberg RF,OF,LF or others much easier to handle. These continue to be made in USA ( my shop) with all stainless steel fasteners, and come with the bracket to mount to a model T steering column. $165 postpaid to you door. Tmorsher@icloud.com to reach me, PLEASE NO PMs or messages here. I may or may not do another batch in the late fall.THANKS! T
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Accessory Stromberg choke control
Post by Henry K. Lee » Thu May 30, 2019 6:20 pm
Very nice product Tim, very happy with the two I received from you.
All the Best,
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Post by Bill Crosby » Thu May 30, 2019 6:37 pm
Tim, Could you post a picture of your choke control mounted on the steering column.
Bill
Dropacent
Last Name: Morsher
Post by Dropacent » Thu May 30, 2019 8:46 pm
Thanks Hank, nice words coming from another blacksmith ! Bill, I’m attaching some photos. The LF instructions state about 10” from top of steering post. I’ve found about 4 phat phingers phrum the quadrant is in the ballpark. This gets you right above the horn wire tube, if you have one.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Fri May 31, 2019 3:14 am
I had one of Tim's choke controls and then sold it because I found an original. Let me tell you, there is almost no difference between the two, other than the cable, Tim, I think that coated cable was definately the way to go. Dave
1925 mostly original coupe.
* REQUIRED* Type and Year of Model Ts owned: '13, '15, '19, '23
Post by Scott_Conger » Sun Jun 02, 2019 1:27 am
I agree
this is a great product, faithfully reproduced.
NH Full Flow Float Valves
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 10, 2019 12:43 am
On some of the last of these I shipped, I’ve been supplying with a braided stainless steel choke wire instead of the solid. When I shipped them , I used a small ferrule crimped on the end to keep the wire from unwrapping. It’s really good wire and doesn’t seem to, but I did it anyway. I’ve wired a couple of ferrules to the end, so for most applications ( the OF ) just cut off the one I crimped , and use a new one if needed when you get it adjusted. I’ve attached a picture. On some applications, you may want two crimped, one on each side of the arm, such as the RF installation. I’m not much for written instructions to include, perhaps I should have, but if anyone needs help, just ask, tmorsher@icloud.com
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 10, 2019 12:44 am
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Jan 16, 2021 7:51 pm
Tim,
Probably in my haste like a kid at Christmas I may have thrown out my column mount. Can I purchase a spare?
