Sold F/S Hastings Taper Gage NEW even Lower price $35+ride
Posted: Fri Mar 15, 2024 10:46 pm
by Craig Leach
Period Hastings Taper Gage in box ( box not super great) Absolute Guarantee will replace or repair without charge at any time gage fails to
function is printed on the box. was $100 now $80 Now $65+ the ride. Now $50 + the ride One more try $35 + shipping six0two-7six9-0two57
Re: F/S Hastings Taper Gage Lower price
Posted: Thu Mar 21, 2024 11:58 pm
by Craig Leach
post again
Posted: Fri Mar 22, 2024 2:27 am
by WorldChamp1914
What does it measure?
Posted: Fri Mar 22, 2024 8:01 am
by JTT3
Taper in cylinder
Posted: Fri Mar 22, 2024 5:02 pm
by Craig Leach
John is correct it measures cylinder tapper ( not bore size ) Made by >-Hastings->piston ring Co. Although the instructions tell how to use it with
a outside micrometer for bore size. A period tool that does the same as the Starrett 452-B that I have used for decades. But Starrett 452-B's now
sell used for $250 & new for over $700.
Craig
Re: F/S Hastings Taper Gage NEW Lower price
Posted: Mon Apr 01, 2024 1:01 pm
by Craig Leach
Back to the top
Posted: Mon Apr 01, 2024 1:06 pm
by ModelTGal
Pardon my ignorance, but why/how would there be a taper in the cylinders???
Posted: Mon Apr 01, 2024 3:44 pm
by Craig Leach
Hi Jennifer,
There is more combustion pressure & less oil at the top of the cylinder so the rings tend to cause more wear @ the top.
The rings don't travel all the way down the cylinder so there is also less wear @ the bottom Of the cylinder. Excessive
taper will cause the rings to flex & break or not make good contact with the cylinder leading to compression loss.
Rotational force can cause the cylinder to wear out of round which can be detected with the same gage. It is almost impossible
to detect a few thousands of an inch with the naked eye & if you could you would need to measure it accurately.
Posted: Mon Apr 22, 2024 11:10 am
by Craig Leach
Still for sale
Re: F/S Hastings Taper Gage NEW even Lower price
Posted: Wed Feb 05, 2025 8:02 pm
by Craig Leach
Even lower price
Re: F/S Hastings Taper Gage NEW even Lower price $35+ride
Posted: Tue Nov 04, 2025 11:54 am
by Craig Leach
Much lower price
