SOLD: another Stromberg LF - complete with dirt
Posted: Thu Mar 28, 2024 5:01 pm
Complete LF
not as good as an OF, but not $400, either
'Way better than an NH
EMAIL ME
Don't reply here and expect a quick answer or an answer at all
- complete including the float and the often-missing larger version acorn nut which no one makes
- potmetal venturi looks fine (I can detect no chips using a strong light and peering down the throat). Don't attempt to remove or you'll destroy it for certain.
- throttle shaft in decent shape with little wear
- high speed knob has very firm ratchet and will not slip
- low speed "click" spring has come loose and needs to be re-riveted to the body - it is still there, being captured by the adjustment knob
- no obvious evidence of being "mucked with" by anyone - appears "as-is" and will need some heat to liberate some rusty screws for replacement
EMAIL ME
