Sherman Sure Fire Twin Plug Head
Tea_time_racer
First Name: Antonio
Last Name: Piery
Post by Tea_time_racer » Sun Jun 02, 2019 9:13 pm
I have unused Sherman Sure Fire twin plug head, great for a speedster project, or other T powered cars. $700 plus shipping
babychadwick
First Name: Chad
Last Name: Azevedo
Re: Sherman Sure Fire Twin Plug Head
Post by babychadwick » Sun Jun 02, 2019 9:52 pm
Will you be at the endurance run?
Tea_time_racer
First Name: Antonio
Last Name: Piery
Post by Tea_time_racer » Sun Jun 02, 2019 9:57 pm
No I wont be, but will be at the LA roadster show on fathers day in June and the Long Beach Model T swap met in July
Tbz4u
Last Name: Weitzel
MTFCA Number: 22631
Post by Tbz4u » Sun Jun 02, 2019 11:39 pm
Trade ya for some. American wheel caps , buffalo caps
Tea_time_racer
First Name: Antonio
Last Name: Piery
Post by Tea_time_racer » Mon Jun 03, 2019 2:27 pm
Thanks for the offer, but at this time I want to sell this.
Mike Lebsack-Iowa
Last Name: Lebsack
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Mon Jun 03, 2019 3:13 pm
Hi.
What is the large hole in the rear center for? Mike
John bevardos
Last Name: bevardos
Post by John bevardos » Mon Jun 03, 2019 3:22 pm
mike, its to add a temp sensor ---if wanted . John
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Mon Jun 03, 2019 10:36 pm
Temp sensor or zinc electrode to prevent electrolysis
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Jun 03, 2019 11:23 pm
Interesting that the plugs are offset- I've seen a lot of Sherman heads and I don't recall ever seeing a twin spark with the holes offset like this one.
kmatt
First Name: Kevin
Last Name: Matthiesen
MTFCA Number: 11598
Post by kmatt » Tue Jun 04, 2019 1:38 am
Dan, I noticed the offset spark plugs also. The plugs more back from the ports are intake, could it be for a little more cooling in the head to help with the incoming mixture not to detonate ? With the pipe plug hole at the back top of the head I have seen a cooling pipe added that runs to the front cooing outlet to help promote cooling flow in the back of the engine.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Tue Jun 04, 2019 8:07 am
My money would be on larger intake valves and the desire to place the plug directly over the valve.
kmatt
First Name: Kevin
MTFCA Number: 11598
Post by kmatt » Tue Jun 04, 2019 3:09 pm
Yes Chadwick you are correct, the offset would help with bigger intake valves and port work. Have a good run with your mom's speedster on Sunday.
blgitn
First Name: Roger
Last Name: Harmon
MTFCA Number: 16412
Post by blgitn » Tue Jun 04, 2019 9:33 pm
So; how much larger can you go with intake and exhaust valves?
blgitn
First Name: Roger
Last Name: Harmon
MTFCA Number: 16412
And where can I read more about it?
Post by Mark Gregush » Tue Jun 04, 2019 9:58 pm
Roger you might want to move your question over to the forum. You would have a better chance of getting an answer there, more eyes.
1921 Huckster
Tea_time_racer
First Name: Antonio
Last Name: Piery
Post by Tea_time_racer » Tue Jun 04, 2019 10:14 pm
Sold
Tbz4u
Last Name: Weitzel
MTFCA Number: 22631
Post by Tbz4u » Sun Jun 09, 2019 9:31 pm
Thats a nice head talk to jerrt sherman junior on oversize valves chad is right
