engine joe model t head
Posted: Tue May 28, 2024 10:09 pm
by tom leroux
any one know any thing about this head
Engine Joe on head
thanks tom leroux
Re: engine joe model t head
Posted: Tue May 28, 2024 10:40 pm
by TRDxB2
Engine Joe on head
thanks tom leroux
"Joe Gemsa" ? doubt it. A picture is needed
Posted: Tue May 28, 2024 10:47 pm
by schwabd1
"Engine Joe" Bell in Tiffin, Ohio had some heads cast a couple years ago......
Posted: Wed May 29, 2024 6:28 am
by Joe Bell
I made a dozen of them in cast iron, the time it took to machine was not worth what people would pay for them, I did make a couple that got used on some interesting projects.
Posted: Wed May 29, 2024 4:48 pm
by Dan Hatch
How about a picture?
Posted: Wed May 29, 2024 9:34 pm
by tom leroux
Joe bell
did you put your name on the head,
engine joe
will get photos
Posted: Wed May 29, 2024 9:57 pm
by Joe Bell
we played with this head for a while first one was 90 lbs. cut it and sliced it to figure out how to lighten it, got it down to 45 lbs. a couple friends have them and two where sold, a good friend machined them and added Engine Joe on it. Les had a couple he cut down to make a really high compression head for his five main block.
Posted: Thu May 30, 2024 3:00 pm
by Joe Bell
Bob at Gaslight has one on the shelf, he may sell it?
Posted: Thu May 30, 2024 4:13 pm
by TWrenn
Posted: Thu May 30, 2024 9:20 pm
by Craig Leach
I think I found one of the 90# heads @ a swap meet in Arizona a few years ago, didn't buy it because of the weight. Wish I had. I picked up a
Ricardo head that is pretty heavy also but both look to have a lot of coolant capacity & would good in the southwest. Joe what was the
compression ratio of those heads & can they be run with high compression pistons?
Posted: Fri May 31, 2024 6:21 am
by Joe Bell
Craig ,I left plenty of casting to mill more off to raise compression if wanted and no you could not run high compression pistons with it.
