Pack nut accessory clamp
Posted: Wed Jul 03, 2024 9:06 pm
by Mopar_man
Anyone know where i can get one? Seems Rattles is living up to his name. Everyplace seems to be out of stock. I know I can make one but I'd like to get the accessory if someone has one.
Rob
Re: Pack nut accessory clamp
Posted: Thu Jul 04, 2024 8:25 pm
by DHort
You can make one with a hose clamp and a bent piece of metal. That is all they are.
Posted: Thu Jul 04, 2024 9:27 pm
by speedytinc
Nut, manifold or both threads must be weak. Clamps are not necessary with good parts.
A little anti-seize & get real tight should do the job with no clamp needed.
Posted: Thu Jul 04, 2024 10:26 pm
by Ed Fuller
You don’t even need to bother with the bent piece of metal. Just put a hose clamp around the exhaust pipe and tighten it right up against the nut.
Posted: Fri Jul 05, 2024 8:46 am
by Jerry VanOoteghem
Ed Fuller wrote: ↑Thu Jul 04, 2024 10:26 pm
How does that prevent the nut from turning?
Posted: Fri Jul 05, 2024 8:49 am
speedytinc wrote: ↑Thu Jul 04, 2024 9:27 pm
"Real tight" is nice, but don't go nuts. You'd be surprised how thin the manifold casting is. Once you break one off, you'll be surprised. (No, not me. I break mine by dropping them
Posted: Fri Jul 05, 2024 10:55 am
by ModelTWoods
Anything, including a hose clamp or even a 1 1/2" muffler clamp, placed as close to the exhaust nut as possible, will keep the nut from turning and backing off, or if no threads, from falling off. The theory is the same as double nutting a bolt tor stud to keep the first nut from backing off.
Posted: Fri Jul 05, 2024 5:07 pm
by Mopar_man
I found that Texas T parts have them. The nut is new but I bet the manifold threads are not that good. Thanks for all the input.
Posted: Sat Jul 06, 2024 10:40 am
by Ed Fuller
Jerry, like Terry Woods said. A hose clamp installed on the pipe and jammed right up against the back of the nut will keep the nut from backing off.
