				Looking for spare 21” Rim and mount for ‘26 Coupe.  FOUND!!!
				Posted: Wed Jul 24, 2024 12:15 pm
				by Hangmancalif
				Need spare rim 21” and rear mounting bracket for a ‘26 coupe.  Any suggestions appreciated.  My current wheels are wood spoke and the detachable rims are 4 lug.   I just need the rim (with tire) as well as the Y type mount for the rear of the car.  I appreciate any info and help.
				Re: Looking for spare 21” Rim and mount for ‘26 Coupe
				Posted: Wed Jul 24, 2024 12:41 pm
				by RajoRacer
				Coupe & Runabout "spools" had 2 types - 3 hole & 4 hole mounting pattern - I might have one - need to verify which type.
				Posted: Wed Jul 24, 2024 12:48 pm
				by Kevin Pharis
				Have a spool also, have confirmed it is a 4 hole.  Please clarify “rim”.  Wood wheel rim?  If so, do you need the “Y” to support the rim?
				Posted: Wed Jul 24, 2024 1:15 pm
				by Karl Von Neumann
				I have the mounting bracket and spool
				Posted: Thu Jul 25, 2024 8:40 pm
				by Craig Leach
				Hi Lee,
Is this what you are looking for?
I believe it bolts to the other mount shown.
				Posted: Fri Jul 26, 2024 1:28 am
				by Allan
				The Y piece comes in two sizes, for 21" and 23" rims. From the photos of the car, you need the 21" size. I have both but I do not know the difference in measurements. Just letting you know there is a difference.
				Posted: Wed Jul 31, 2024 2:38 am
				by Hangmancalif
				Thank you sir.  I appreciate that info!
				Posted: Wed Jul 31, 2024 10:33 am
				by Karl Von Neumann
				I have them sent you an email last week...
				Posted: Wed Jul 31, 2024 11:02 am
				by Dan Hatch
				Hardest part to find are the special thin nuts to hold Y on the spool.
				Posted: Wed Jul 31, 2024 11:34 am
				by RajoRacer
				Lang's has them !
				Posted: Wed Jul 31, 2024 12:33 pm
				by Dan Hatch
				That is cause real ones are hard to come by.
				Posted: Wed Jul 31, 2024 3:04 pm
				by ModelTWoods
				Everyone has mentioned the 'spool' that mounts the Y to the rear trunk panel, and the Y, itself, but the poster stated that he needed a spare rim, too, and no one has offered one. The 21" rims came with two locking mechanisms. The early used a pivoting latch, rivited to the rim, and the later, used a special round headed, slotted bolt to secure the ends together. The owner would have to remove one or more rims from his wheel fellows to see which rim he needs. If he has the early rim, I may have an extra which is zinc plated as original, but I'll have to check to see if I still have it.
				Posted: Wed Jul 31, 2024 5:18 pm
				by RajoRacer
				They will both mount up to the wheel - doesn't matter which latch it has.
				Posted: Wed Jul 31, 2024 6:15 pm
				by JTT3
				Steve’s got a point, I thought there were 3 styles of locking split rims, the one with the tab & bolt, the one with the movable lock latch over the rectangular bar & the pin lock similar to a hinge connecting bolt that joins the two sides.
Could be wrong though. On 2nd thought may be another, the one where the connector is broken off and some how brought together without any locking mechanism, that’s a joke but have seen it done. Not the best idea though. Best John
				Posted: Wed Jul 31, 2024 6:57 pm
				by Kevin Pharis
				Dan Hatch wrote: ↑Wed Jul 31, 2024 11:02 am
Deez nutz…?
				Posted: Wed Jul 31, 2024 7:22 pm
				by RajoRacer
				Canadian rims used the "hinge & pin" type of latching arrangement.
				Posted: Wed Jul 31, 2024 11:27 pm
				by ModelTWoods
				RajoRacer wrote: ↑Wed Jul 31, 2024 5:18 pm
I know both will work. I was just speaking as a 'perfectionist".
				Posted: Sat Aug 03, 2024 12:52 am
				by Kevin Pharis
				Posted: Fri Aug 09, 2024 2:00 am
				by Hangmancalif
				Thank you.
