FS 11 tooth pinions ( non script sold)
Posted: Fri Oct 18, 2024 11:50 am
by Craig Leach
FS Pinions 11 tooth One Ford script with some small pits (copper colored) & one non script $ 50 each + the ride
Craig.
Re: FS 11 tooth pinions
Posted: Fri Oct 18, 2024 6:11 pm
by Kerry
It could be possible that the one with the dot is a later one and needs to match a ring gear with a dot as well.
Posted: Fri Oct 18, 2024 7:02 pm
by Craig Leach
Hi Frank,
To the best of my knowledge that is that dot is a hardness test mark I certainly hope its not as I have never seen a ring gear with a dot?
Every ford script pinion I have seen I believe has that dot. It is also on the other end of the gear.
Craig.
Re: FS 11 tooth pinions ( non script sold )
Posted: Tue Oct 29, 2024 10:46 pm
by Craig Leach
To the top. All of the pits in the Ford script pinion are in the pics. They do not appear to be rust or flaking. looks to have been run long after
they where made.
Posted: Tue Oct 29, 2024 11:47 pm
by Ken Buhler
Hello Craig, we haven't spoken for quite a while. I'm looking forward to an update. I would like to buy the one on the left.
Ken
Re: FS 11 tooth pinions ( non script sold)
Posted: Wed Oct 30, 2024 10:06 am
by Craig Leach
Non script pinion sold Thanks Ken.
Craig.
