WTB fork mounted license plate bracket
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Sat Nov 30, 2024 8:35 am
Howdy,
I’m looking for a brass era headlight fork license plate mounting bracket.
Regards,
Re: WTB fork mounted license plate bracket
Post by Allan » Sat Nov 30, 2024 6:21 pm
Joe, there was one which bolted around the headlight stalk on the electric headlights. It may be the same as the one you are searching for.
* REQUIRED* Type and Year of Model Ts owned: Speedsters (1919 w 1926), 1926
Post by TRDxB2 » Sat Nov 30, 2024 7:08 pm
There are two that I am aware of
#871 for pre 1915 (2nd down on the left)
#440 no picture but this has been reported for Canadian Models
Post by Allan » Sat Nov 30, 2024 11:40 pm
Frank, that Canadian one is the one I recall. It should fit all single stork light mountings.
Post by TRDxB2 » Sun Dec 01, 2024 1:00 am
Looks like the Neverout #440 isn't the same as the Canadian mount & could be made quite easily
Could be a DIY
havnfun
First Name: Joe
Post by havnfun » Wed Jan 01, 2025 12:27 pm
Still looking….
Regards,
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Jan 01, 2025 1:31 pm
Only one I ever found. Good luck.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Jan 06, 2025 1:17 am
The bracket pictured clamped to the fork is on my 1912 touring it was on the car in 1960 a complete running car my thought is it is from 1915 or later because the early Manitoba plates are short that is why there is an extra hole so I can put the 12 plates on the car . It is an original Winnipeg Manitoba Canada car built in Walkerville Ontario.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Jan 06, 2025 1:39 am
I stand corrected I found a ad from 1913 specialty auto parts New York NY states it will fit all fords form 1911 through 1913
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Jan 06, 2025 1:40 pm
This ad is from 1914 so they are a US item there should be loads of them out there Cheers Colin
