1926 Holley NH carburetor/Sold
Topic author - Posts: 634
- First Name: Corey
- Last Name: Walker
Pressure tested tall float for cowl mounted tank, passages cleaned and sealed with set screws, reconditioned spray needle, new spray nozzle and 1/8” oriface (full flow) float valve installed, test run. $245 postpaid to continental USA email: wlkma9@gmail.com
You do not have the required permissions to view the files attached to this post.
Re: 1926 Holley NH carburetor
Note: Valve shown is a copy, and is NOT one of my Full Flow Float Valves
NH Full Flow Float Valves
- First Name: Corey
- Last Name: Walker
I never said it was one of yours, Scott, just that it is one and it works just the same. I’m not selling them separately, just including one that I made so that someone doesn’t have to purchase one separately later. I’m not selling them separately but if you can modify a part to go into a 100 year old car so can I. I don’t work on that many NH’s so I don’t imagine you will go bankrupt because I made a couple to go into my own rebuilds.
