This is a Dubats crankshaft with less than 100 miles run on it. I rebuilt an engine using this crankshaft late last year. The block had a thin water jacket from a poor machining job on the manifold surface that started to leak shortly after putting it in service. I gave up trying to fix it in the car. I built up a new engine and swapped it out so I wouldn't be down for months this summer, now I don't have a use for this. It was new in the box until last year. I had it micro polished to remove the little bit of surface rust that was on the journals but it did not require grinding.
The rod journals measure 1.247 - 1.2475; mains measure 1.2475-1.248. The journals measure straight and round, variation is between the journals.
I had rod and main bearings done by Vic Tyrel at Antique Engine Bearing Service. I had 5 rods done so I'd have a spare. The rods are marked to identify what cylinder they were in so it's easy to use them. The rod and wrist pin bolts are new Snyder's bolts. The rods are drilled for dippers and X'd.
There is a new timing gear installed.
The crankshaft is $1,475.
The set of rods are $300 with the crankshaft.
Plus actual shipping and insurance unless you can pick it up.
If whoever buys the crankshaft wants to take on trying to repair the block They can have it with main bearing caps and bolts, but I'll want a good set of main bearing caps and bolts exchanged. The block is a 1914 (that's why I tried to use it). The babbit in the block also has less than 100 miles on it. The block was bored and honed at +.060 and has hardened seats in the exhaust. I've also got the valves and lifters for it; I planned to keep those but we can work something out. I don't have pictures of the block right now but if you buy the crank and rods I'll take some and send them.
Dubats Crankshaft, Connecting Rod Set
Topic author - Posts: 338
- First Name: Gary
- Last Name: London
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring
- MTFCA Number: 16592
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
Re: Dubats Crankshaft, Connecting Rod Set
Hi Gary, remember me? Has any balancing been done? What pistons would be good to use with these rods? I believe you have my contact info. Cheers, Bill
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
You do five rods and you will never need it, I have never heard of a dubatt's crank failure to bad he did not keep making them, competition never hurts on pricing.
- First Name: Gary
- Last Name: London
The crankshaft is sold.
