Got them. Want to buy Rocky Mountain brake pad only
Posted: Sun Jan 12, 2025 6:20 pm
by Sarikatime
On a tour my drivers side rear brake must have been too tight and it got hot and cought on fire.
I need either a Rocky Mountain brake pad or the pad and the metal it is riveted to.
If you have one or know where to get one, please let me know.
The Rocky Mountain Brake Company is not operating at this time and may or may not ever.
Thank you,
Frank Seress
sarikatime@yahoo.com
Eight one eight two Five four six seven nine seven.
Re: Want to buy Rocky Mountain brake pad only
Posted: Sun Jan 12, 2025 6:25 pm
by speedytinc
Mc Master carr sells a great woven replacement. Specify width, thickness & length.
I prefer this material to the hard solid linings as installed originally.
Posted: Sun Jan 12, 2025 6:36 pm
by Karl Von Neumann
You can buy lining by the foot on ebay
Posted: Mon Jan 13, 2025 4:04 am
by Allan
If you are going to reline one shoe, the other should be done with the same material, or you may have different braking forces due to different co-efficients of friction in brake lining materials at the two wheels.
Allan from down under
Posted: Mon Jan 13, 2025 12:25 pm
by Steve1920
Not to hijack this thread, but what has happened to the Rocky Mountain Brake Co.? Illness, retirement, wildfires, worse?
Thanks.
Steve
Posted: Mon Jan 13, 2025 12:44 pm
by jsaylor
I relined my Rockies with the McMaster Carr woven. Stops great but was wearing groves into the drum. 26-27. Removed it and got molded lining from Chaffins. They carry several kinds.
Posted: Mon Jan 13, 2025 1:12 pm
by RajoRacer
A friend of mine just spoke to Bud's son, apparently Bud has been diagnosed with Dementia but his son intends on continuing the business from what my friend understood.
Posted: Mon Jan 13, 2025 8:07 pm
by Ralph F
I was able to purchase lining form Langs.
Fitz
Posted: Tue Jan 14, 2025 8:00 am
by Sarikatime
Thank you guys for all the information. Finally got linings from Langs.
Posted: Tue Jan 14, 2025 12:22 pm
by Mark Gregush
jsaylor wrote: ↑Mon Jan 13, 2025 12:44 pm
Wondering which lining you got as the brass wire should not have been hard enough to wear grooves in the drums? Did you not counter sink the rivets, which I could see as being the reason for the grooves. And yes, you can counter sink the rivets on woven lining.
I would not use any type of hard lining on pressed steel drums only cast iron. It has been said over and over again to only use woven lining on that type of drum.
