Stromberg OF, and LF and a Holley G
Posted: Wed Jan 29, 2025 4:04 pm
I have three rebuilt carbs. Both of the Strombergs were also engine tested. The Holley G is correct for a '15-'16 and has a new float and throttle shaft bushings. The Stromberg LF has a new fuel level shaft/needle, pressure tested float, new throttle shaft bushings, a fuel level sight plug, and it runs and adjusts perfectly. The Stromberg OF has also been totally restored and engine tested. It also has a new fuel level shaft and tip, a pressure tested float and throttle shaft bushings plus a fuel level sight plug. Asking $275.00 for the Holley G, $450.00 for the LF and $600.00 for the OF, all including shipping.
