Model B crankshaft
Posted: Thu Apr 10, 2025 1:26 pm
by Gene_French
Model B Ford 4 cyl. crankshaft ... this shaft should be re-ground , BUT is in good serviceable condition ... i have noted the rod and main bearing sizes in the photo ... this is a NON-COUNTERWEIGHETED crankshaft , but counterweights can be added by welding ... a great way to add strength to the bottom end of a motor and can be re-ground to produce a stroked crankshaft by simply using Model A rods or custom made rods ... this crankshaft is HEAVY and NOT CHEAP ... can be picked up here in northern Colorado or Fed-Ex shipped at customers cost ...price is $450 PLUS shipping ... contact me thru the MTFCA site ... Gene French ...will add photos later ...have to re-size
Re: Model B crankshaft
Posted: Thu Apr 10, 2025 2:26 pm
by Gene_French
photos and dimensions for mains ... mainbearing diameter 1.991" thru 1.995" ... center main is worn the most ...should grind at minus .020" ...Gene French
Posted: Fri Apr 11, 2025 7:15 am
by Dan Hatch
Gene: Could you post a picture of the whole crankshaft?
Trying to see how to ID a B crank. Thanks Dan
Posted: Fri Apr 11, 2025 9:55 am
by Gene_French
Dan:
here is picture of crankshaft ... same shape and lengths of model A crank , just bigger mains and rods ... the early B and BB were not counterweighted ... later they added the pinned inplace counterweight , then the integral counterweight ...hope this helps you to identify the crankshafts ...model A mains were 1.625 and rods were 1.500 ... model B mains were 2.000 and rods were 1.875 ...
Posted: Fri Apr 11, 2025 12:32 pm
by Dan Hatch
Thanks Dan
Posted: Sat Apr 12, 2025 3:04 pm
by Gene_French
Have added 5 B rod cores and a B carb. to the classifieds ... may find more B items as i dig deeper into storage ... i believe there are several B distributors and manifold sets somewhere in this pile of stuff!
Posted: Sat Apr 12, 2025 9:35 pm
by Henry K. Lee
There is so much you can do with a Model B crank, easy to balance with added metal, easy to weld on as the metal quality is far past others. The mains are a bit of a challenge in a T block and possible by means of spreading out the attachment bolts. And if you want to break the rules..., do an offset of the main bearings for the ultimate screamer! Honda motorcycles did this with their inline fours. Just Sayin'
Posted: Fri Apr 18, 2025 8:44 am
by Gene_French
to the top ...thanks MTFCA
