WTB Kelsey outer rim
Posted: Mon Jul 07, 2025 7:58 pm
Need a Kelsey outer rim that uses 30 x 3 1/2 tires
And takes the stud bolts holding clips and nuts.
The outer rim has one tab near the valve stem and has the ridge going completely around the outer edge with 4 slits the hold the 4 clips that grip the fellow of the inner wheel. Using for a spare tire.
Thank You MTFCA
LARRY
EMAIL: ltlapatka@gmail.com
Thank You MTFCA
LARRY
