FS Large homebuilt beadblasting cabinet.
Topic author - Posts: 143
- Last Name: Grisbee
- * REQUIRED* Type and Year of Model Ts owned: 0
It's about 3'x3'x5' so it's pretty goodsized. On wheels so with the handles it's very easy to roll around. It did have some sort of vent straight up but that has been removed. You don't want to breathe that powdered glass so a regular blaster vacuum like Scatblast sells should be obtained and used and even then they recommend a face mask. It's out of an estate so there was no one to ask about the piping to the nozzle,some familiarization and some new works may be required. The thing was built out of plywood but there is some sheetmetal on the back panel inside. I'm selling it "as-is,where-is"but if someone is planning on building one it would be a head start. So it will need to be picked up but no giant rush getting it out of here. It was used outside on a patio so the angle iron brackets that can be swung out over the glass believed to hold a piece of plywood to shield glare from the sun. A Scatblast catalog is included. Price is $150 check or paypal,please PM me if interested.
Re: FS Large homebuilt beadblasting cabinet.
Would it help if I offered delivery within 50 miles?
