Model T parts for sale
Topic author - Posts: 12
- First Name: Mitch
- Last Name: Owen
Below is a photo and list of items for sale and prices (excluding shipping). Please email me at mitch.owen@swbell.net if you are interested. When responding please include your mailing address so shipping costs can be determined.
Ignition switch assembly (used)- $20.00
Crank pulley- $25.00
Original Heinze switch- $115.00
Radiator cap- $5.00
Dash to windshield brackets- $10.00
Hot air pipe #1- $15.00
Hot air pipe #2- $10.00
Timer (no roller)- $15.00
Timer w/roller- $20.00
Rod bending tool- $30.00
Water pump pulley?- $5.00
Brass valve stem covers (4)- $45.00
(2) brass hub caps- $10.00
Brass oil site gauge- $25.00
Carbide generator basket- $10.00
Headlight glass w/ (small hole)- $5.00
Brass rear view mirror- $30.00
Cylinder water lower inlet connection- $15.00
Roller bearings - original style (4)- $65.00
Original style hose clamps (30) & hoses- $20.00
Break rod support brackets (3)- $25.00
Generator block off plate (new)- $12.00
Model XF carb off a speedster project- $35.00
Radiator cap- $5.00
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Model T parts for sale
Your "rod bending tool" is actually a Babbitt pouring fixture for a T rod - FYI.
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
- MTFCI Number: 24878
PM, and email sent on Brass Valve Stem caps
Regards,
Joe Kowalczyk - 1923 Touring, 1913 Speedster, 1913 Runabout
Email: havnfun@cableone.net
(208) 870-3099
(208) 870-3099
- First Name: Mitch
- Last Name: Owen
The used ignition switch, Dash to windshield brackets, rod bending tool, brass valve stem covers, generator basket, and cylinder water lower inlet connection are spoken for pending payment.
- First Name: Dennis
- Last Name: Michaud
- Board Member Since: 2010
I'll Take the 3 Brake rod supports, Please send me a Pm, thanks , Dennis
- First Name: Robert
- Last Name: Weitzel
- MTFCA Number: 22631
I'll take carb and oil site gage robertaweitzel@gnail.com
- First Name: Mitch
- Last Name: Owen
If you are wanting a part or two, please send email to mitch.owen@swbell.net thank you.
- First Name: Rich
- Last Name: Jesteadt
- MTFCA Number: 50484
- MTFCI Number: 24737
I'll take the rear view mirror. I just sent you an email.
- Last Name: Robbins
- MTFCA Number: 30323
- Board Member Since: 2012
I will take the hose clamps. THANKS,STEVE
- First Name: Mitch
- Last Name: Owen
Still available:
Crank pulley
Heinze switch - reduced to $85.00
radiator cap
Hot air pipes #1 & #2
Timers
water pump pulley
Headlight glass
generator block off plate
Please email mitch.owen@swbell.net if interested
Crank pulley
radiator cap
Timers
water pump pulley
Headlight glass
